I need to do a belt change on my Beocentre 8000 cassette mechanism - it's starting to sound dreadful, I don't know what version I have but I've extracted the mechanism and I can see three belts, 2 very easy to change and one wider belt inside. It looks like I need to remove the bottom plate to begin (same side as the motor pulley), but has anyone got any hints or tips before I start ?
When you order a belt set (beoparts-shop) leave a note at the checkout page stating your Beocenter model to have mounting instructions included.
Hi Martin,
Do you have the guide for replacing the belts (I have the 3 belt version) in a beocenter 8000 and if so can you send a link. ? I´ve bought the belt set af beoparts, but didn´t know that I could leave a comment to get the instructions included.
Are you running the beoparts shop? (just curious :-) )
mvh Jesper (also from denmark)
I'm not running the webshop, but the shop is always ready to help.I'm sure you will receive an email shortly.If not, I suggest you use the webshops contact form.
They were quite fast, so i've received a mail from them already. :-)
Thanks alot :-)
