Beocentre 8000 belt replacement
This post has 4 Replies | 0 Followers
Tim
Somerset, UK
Posts 27
Tim Posted: Tue, Jan 26 2021 10:00 PM
I need to do a belt change on my Beocentre 8000 cassette mechanism - it's starting to sound dreadful, I don't know what version I have but I've extracted the mechanism and I can see three belts, 2 very easy to change and one wider belt inside.   It looks like I need to remove the bottom plate to begin (same side as the motor pulley),  but has anyone got any hints or tips before I start ?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Jan 27 2021 8:09 AM
When you order a belt set (beoparts-shop) leave a note at the checkout page stating your Beocenter model to have mounting instructions included.
gastron
Posts 6
gastron replied on Wed, Jan 5 2022 7:03 PM
Hi Martin,
Do you have the guide for replacing the belts (I have the 3 belt version)  in a beocenter 8000 and if so can you send a link. ? I´ve bought the belt set af beoparts, but didn´t know that I could leave a comment to get the instructions included.
Are you running the beoparts shop? (just curious :-) )
mvh Jesper (also from denmark)
Dillen
Posts 13,191
Dillen replied on Wed, Jan 5 2022 8:31 PM
I'm not running the webshop, but the shop is always ready to help.
I'm sure you will receive an email shortly.
If not, I suggest you use the webshops contact form.
gastron
Posts 6
gastron replied on Wed, Jan 5 2022 9:07 PM
They were quite fast, so i've received a mail from them already. :-)
Thanks alot :-)
Page 1 of 1 (5 items) | RSS
