This is my first post in this forum. I hope someone might be able to help me.😊
I’ve got a pair of great beolab penta mk3. The sound is awesome! Only issue i have is that there is a loud ”bang” whenever i change the source input and when i power off.
Anyone have the same problem and what might be done? Recaping?
thanks for you help!
Mike
Having exactly the same problem. Would love to get some advices from the forum.
Problem solved!
After a full recap and changing the TR 23,28 on the main board and still having the penta pop i focused on the inputboard and transformer.
i Changed the 10000uf caps on the tranformer, not sure this was needed but did it anyway.. Then i changed the IC1 and IC2 on the inputboard (PCB 22) after putting everything together the” pop” was gone! My best guess is that the issue was a faulty IC on the PCB 22.
Hope this might help someone with the same problem!
/Mike
