Beolab penta 3, loud pop [Solved]
This post has 2 Replies | 2 Followers
Raven_mike
Posts 2
Raven_mike Posted: Sat, Jan 30 2021 10:06 AM
This is my first post in this forum. I hope someone might be able to help me.😊
I’ve got a pair of great beolab penta mk3. The sound is awesome! Only issue i have is that there is a loud ”bang” whenever i change the source input and when i power off.
Anyone have the same problem and what might be done? Recaping?
thanks for you help!
Mike
Keith
Budapest
Posts 3
Keith replied on Tue, Feb 9 2021 9:33 PM
Having exactly the same problem.  Would love to get some advices from the forum.
Raven_mike
Posts 2
Problem solved!
After a full recap and changing the TR 23,28 on the main board and still having the penta pop i focused on the inputboard and transformer.
i Changed the 10000uf caps on the tranformer, not sure this was needed but did it anyway.. Then i changed the IC1 and IC2 on the inputboard (PCB 22) after putting everything together the” pop” was gone! My best guess is that the issue was a faulty IC on the PCB 22.
Hope this might help someone with the same problem!
/Mike
Page 1 of 1 (3 items) | RSS
