Connecting BeoVision 4-50 to Beosystem 3
Bo Xamuel
Denmark
Posts 34
Bo Xamuel Posted: Tue, Feb 9 2021 4:49 PM
Hi.
I just got a BeoSystem 3 and a BeoVision 4-50 for next to nothing. So far so good.
Now I'm trying to connect my BV 4-50 to my BS 3. In the manual for the BV 4 it says I'm supposed to connect SERIAL to MONITOR on the BS 3, DVI (Slot 2) to Display 1 on the BS 3 and IR (SLOT 3) to the IR IN (9 pin) on the BS 3. My question is how do I do that since there IS no IR slot on the BV 4??? And then how are the two supposed to work together without the 9 pin IR cable connected between them? I understand from the BV 4 manual it should have a build in IR receiver and work together with the BS 3 using the included 9 pin IR cable.
/ Bo Xamuel
frog
Camberley UK
Posts 624
frog replied on Tue, Feb 9 2021 6:33 PM
Most beovision 4s did not have an integrated IR - so you’ll need an external one.
wiring via either the 3.5mm jack or via the 9-pin plug is posssible. Here’s the wiring for the 3.5mm jack approach.
 https://archivedforum2.beoworld.org/cfs-filesystemfile.ashx/__key/CommunityServer.Components.PostAttachments/00.00.01.63.52/IR-Eye-Connection.jpg
Bo Xamuel
Denmark
Posts 34
frog:
Ok. Thank you, Frog.
I got an IR eye with a 9 pin connector that came with the BS 3. So I should just connect that to the BS 3, and the other cables as advised, and it should work? Just got confused that the manual tells me to connect a cable to a socket that's not there :)
frog
Camberley UK
Posts 624
frog replied on Thu, Feb 11 2021 2:05 PM
Yes - that's all you need to do.
Bo Xamuel
Denmark
Posts 34
Bo Xamuel replied on Fri, Feb 12 2021 12:16 AM
frog:
Yes - that's all you need to do.Smile
So I did, and everything is working just fine now Smile
So I guess the manual I got is for a different model of the BV 4-50, but never mind.
Thanks again
/ Bo Xamuel
DISCODUCK
Posts 14
DISCODUCK replied on Wed, Jan 26 2022 3:18 AM
Hi Frog,I'm very interested in this post as I have a Bv4-50 mk3 which the seller assured me ,has a built in IR receiver so no need for the "magic eye".
However I believe that this screen needs a rather unusual cable to connect to a BS3 which is,I think an RS232 to a "Molex" connector cable.
I will try to add pics of the cable that I'm told that I need.Can you confirm what is actually needed to connect a BV4-5O MK3 to a BS3?
Thanks in advance.
Alan
ps.cant find the option to add files from my pc,sorry
frog
Camberley UK
Posts 624
frog replied on Sat, Jan 29 2022 11:06 AM
The cable you need is this one:
https://archivedforum2.beoworld.org/forums/t/45321.aspx
Page 1 of 1 (7 items) | RSS
