Hi.
I just got a BeoSystem 3 and a BeoVision 4-50 for next to nothing. So far so good.
Now I'm trying to connect my BV 4-50 to my BS 3. In the manual for the BV 4 it says I'm supposed to connect SERIAL to MONITOR on the BS 3, DVI (Slot 2) to Display 1 on the BS 3 and IR (SLOT 3) to the IR IN (9 pin) on the BS 3. My question is how do I do that since there IS no IR slot on the BV 4??? And then how are the two supposed to work together without the 9 pin IR cable connected between them? I understand from the BV 4 manual it should have a build in IR receiver and work together with the BS 3 using the included 9 pin IR cable.
/ Bo Xamuel
Most beovision 4s did not have an integrated IR - so you’ll need an external one.
wiring via either the 3.5mm jack or via the 9-pin plug is posssible. Here’s the wiring for the 3.5mm jack approach.
https://archivedforum2.beoworld.org/cfs-filesystemfile.ashx/__key/CommunityServer.Components.PostAttachments/00.00.01.63.52/IR-Eye-Connection.jpg
frog: Most beovision 4s did not have an integrated IR - so you’ll need an external one. wiring via either the 3.5mm jack or via the 9-pin plug is posssible. Here’s the wiring for the 3.5mm jack approach. https://archivedforum2.beoworld.org/cfs-filesystemfile.ashx/__key/CommunityServer.Components.PostAttachments/00.00.01.63.52/IR-Eye-Connection.jpg
Ok. Thank you, Frog.
I got an IR eye with a 9 pin connector that came with the BS 3. So I should just connect that to the BS 3, and the other cables as advised, and it should work? Just got confused that the manual tells me to connect a cable to a socket that's not there :)
Yes - that's all you need to do.
frog: Yes - that's all you need to do.
So I did, and everything is working just fine now
So I guess the manual I got is for a different model of the BV 4-50, but never mind.
Thanks again
Hi Frog,I'm very interested in this post as I have a Bv4-50 mk3 which the seller assured me ,has a built in IR receiver so no need for the "magic eye".
However I believe that this screen needs a rather unusual cable to connect to a BS3 which is,I think an RS232 to a "Molex" connector cable.
I will try to add pics of the cable that I'm told that I need.Can you confirm what is actually needed to connect a BV4-5O MK3 to a BS3?
Thanks in advance.
Alan
ps.cant find the option to add files from my pc,sorry
The cable you need is this one:
https://archivedforum2.beoworld.org/forums/t/45321.aspx
