Beocord 1200 not playing
kb1981
Posts 8
kb1981 Posted: Fri, Mar 5 2021 2:25 PM
Hi All,
I have owned a beocord 1200 for a while but never really tried using it. It powers up fine, and I can fast forward and rewind but when I set it to play, the mechanism rises, but the tape doesn't roll. Has anyone any experience with this problem and how to resolve it?
Kevin
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Mar 6 2021 7:24 AM
Check for broken belts.
kb1981
Posts 8
kb1981 replied on Wed, Mar 10 2021 8:14 AM
thanks Martin. I've never opened anything up before but perhaps I'll give this one a whirl!
Dillen
Posts 13,191
Dillen replied on Wed, Mar 10 2021 12:23 PM
Take off the tapehead cover and look down.
lvigil
Posts 2
lvigil replied on Sun, Feb 13 2022 11:54 PM
Hello Kevin,
I have the same issue with my Beocord.  I have watched several videos.  From what I gather when you push the lever up to play, this engages almost like a clutch pad on the back side that allows it to play.
My issue is that the back plate is too far away for it to engage.  Supposedly there is a screw that you turn on the front side that adjusts this spacing.  I have turned it both cw and ccw, with no success.
In addition, when I try to rewind, the reel will not rewind.  My belts are all intact and are not worn.
I would imagine it must be something very simple, but my brother and I have not been able to figure it out.
If and when we do I will certainly let you know.
Please let me know if you find something as well.
Good luck,
Polo
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
