hi
im having an issue with my beogram 1600 and i have a ground hum
im unable to find anything out about this deck but know its basically the samr as the 1700 and 1900
anyway i seem the be getting continuity to ground from everywhere
left chanel continuity to ground
right continuity to ground
this is with the din pug removed from the cable
and since they all go to ground i get continuity from l to r as well
is this correct or not
it seems correctly wired here
When the deck is not playing, the left and right signals are both grounded by the muting switch.
ok, is it the same when its unplugged from power and the amp ?
Yes, it's a mechanical switch opetrated by the lift/lower actualtor arm.It's right there in plain view in your photo with the leads soldered to it.
