TX2 - initial problems with tonearm resolved
This post has 9 Replies | 1 Follower
GessWurker
Posts 12
GessWurker Posted: Mon, Mar 15 2021 8:27 PM
I couldn't figure out how to delete my original post, so I'm simply amending it to: Initial problems with tangential tonearm were resolved. It turns out that a missing screw in the base of TX2 I just acquired caused slight misalignment issues for the tonearm dropping and rising. Once I replaced the missing screw in the base, the tonearm functioned perfectly. It dropped neatly into the groove without problems; it rose properly as well. All good now.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Mar 16 2021 7:01 AM
A crackle sound when lifting and lowering could point to a need for a shot of contact cleaner to the muting switch.
Spassmaker
North Germany
Posts 223
Hi
Did you try to put the SMMC on your running TX2?
How does it perform there?
Kind regards
Christian
GessWurker
Posts 12
Right. Turns out it was a simple misalignment (albeit slight). Fixed by making sure BOTH screws in the base of the unit were present and accounted for.
GessWurker
Posts 12
All better now. All I needed was BOTH screws in the base of the unit.
GessWurker
Posts 12
I tried the SMMC4 and it works great!
GessWurker
Posts 12
Spassmaker
North Germany
Posts 223
Congrats and enjoy you vinyl collection.
GessWurker
Posts 12
Dillen: Where is the muting switch? Now I think I may be having a problem with it.
Dillen
Posts 13,191
Dillen replied on Tue, Mar 16 2021 9:33 PM
Where the signal output leads go from.
Activated by a lever from the lift/lower cam.
Page 1 of 1 (10 items) | RSS
