I have just got a beomedia 1 which is due to arrive tommorrow but was wondering if anyone has one of these units running a mac pc, can i connect the pc directly to the unit so i can import my music and videos from itunes or do you have to do this via the network, is the unit easy to set up?
Many thanks
Dean: I have just got a beomedia 1 which is due to arrive tommorrow but was wondering if anyone has one of these units running a mac pc, can i connect the pc directly to the unit so i can import my music and videos from itunes or do you have to do this via the network, is the unit easy to set up? Many thanks
The easiest way is to install Beoconnect.
Copying and registering are done in Beoconnect. Drag and Drop your audiofiles to the Beoconnect icon in the tray.
Copying is done via your network.
If you're planning to copy via an external USB drive directly attached to the BM1, you will need an external mouse and/or keyboard for the BM1.
The latter can be the fastest way to copy.
Thank you, I have just plugged in my beomedia 1 and downloaded the software from the web sire beoplayer. I have had to add the device manually by obtaining the ip address and name, but it is now asking for a password?
I have entered the serial number but this does not work, any ideas what the default password is?
sorry i downloaded beoconnect for mac
