Hi All,
Looking for the best way to connect a Beogram 8002 to a Mk2 Essence by way of a reasonable phono stage.
Any ideas. Bluetooth or simple RCA?
10
I RCA connected a BG4002 to my BS Moment. The Moment starts when the needle "hits" the record.
Simple, straith forward and reliable.
Picking up horrible distortion
BG8002 >> Hyperwire MD001 >> Essence mk2
Connections good, needle ok, thinking there’s not enough signal uplift on the RIAA.
im not an expert in this type of arrangement
Mr 10Percent:BG8002 >> Hyperwire MD001 >> Essence mk2
BG4002 original DIN >> DIN to RCA from Sounds Heavenly >> Oehlbach Phono Preamp Pro >> RCA-RCA cable >> Moment
no distortion at all
So how are your cables / connectors? Did/can you test the preamp with another recordplayer or mike?
As Carolpa explained, you need a preamp (riaa) from Beogram 8002 to the Essence. (The audio signal from a Turntable is to weak for a Beomaster etc)(later BeoGrams, like BG6500, have premp/riaa built in)The quality on preamps differ, see audio tests and on internet. To get the best is for you to decide.See for cables and pre amp also here:https://soundsheavenly.com/search?controller=search&s=8002For other readers here who want the 7 PIN DIN remote control Datalink and riaa/preamp see here:https://www.designedav.com/en/product/riaa-pre-amplifier-for-b-o-mk2Regards, Robert
