beovision 7.40 motorised wall bracket for a beolab 7.4 ?
olvisab
Posts 1,391
olvisab Posted: Sun, Feb 3 2013 12:06 PM
Hello everybody,
I searched this motorised wall bracket for a long time for my beovision 7.40 mk2.
There is one on sale on ebay.de, this one is provided with a plate for a beolab 7.2, according to you, is it possible to change this plate in order to hang a beolab 7.4 ?
Best regards
olivier
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
MartinW
Posts 389
MartinW replied on Sun, Feb 3 2013 2:16 PM
Very easy to do that, just take 2 bolts. The bracket remains the same, you just need a 7.4 mounting plate.
olvisab
Posts 1,391
olvisab replied on Sun, Feb 3 2013 2:39 PM
Thanks Martin for this precious information.
He ask for this 460 euros, it should cost around 1500 euros from new, according to you is it a good opportunity to buy ?
MartinW
Posts 389
MartinW replied on Sun, Feb 3 2013 5:07 PM
Can't really complain - they are quite rare but also in low demand so quite difficult to sell too. One third of the price - i can't say he's asking too much. Seems ok to me. Let me know if you have any issues getting a 7.4 mounting plate - i have one here, you would just need to arrange a courier to collect from the UK.
olvisab
Posts 1,391
olvisab replied on Sun, Feb 3 2013 5:21 PM
Thanks Martin for your kind offer.
I will try to get this one.
Best regards
olivier
olvisab
Posts 1,391
olvisab replied on Mon, Feb 4 2013 9:25 AM
Is it possible to mount a beovision 7.40 + beolab 7 + this kind of heavy wall bracket on a wall in plasterboard ?
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
olvisab:
The manual will usually indicate whether this is possible. The normal requirement is to fix to a full length stud with a specified minimum number of bolts/ screws. If necessary, open up the wall from behind and put in a couple of vertical studs exactly where you need them and at the same time provide a cable run between the studs. Alternatively build a false plasterboard on stud panel in front of the existing wall.
Graham
Page 1 of 1 (7 items) | RSS
