Hello everybody,
I searched this motorised wall bracket for a long time for my beovision 7.40 mk2.
There is one on sale on ebay.de, this one is provided with a plate for a beolab 7.2, according to you, is it possible to change this plate in order to hang a beolab 7.4 ?
Best regards
olivier
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Thanks Martin for this precious information.
He ask for this 460 euros, it should cost around 1500 euros from new, according to you is it a good opportunity to buy ?
Thanks Martin for your kind offer.
I will try to get this one.
Is it possible to mount a beovision 7.40 + beolab 7 + this kind of heavy wall bracket on a wall in plasterboard ?
olvisab: Is it possible to mount a beovision 7.40 + beolab 7 + this kind of heavy wall bracket on a wall in plasterboard ?
The manual will usually indicate whether this is possible. The normal requirement is to fix to a full length stud with a specified minimum number of bolts/ screws. If necessary, open up the wall from behind and put in a couple of vertical studs exactly where you need them and at the same time provide a cable run between the studs. Alternatively build a false plasterboard on stud panel in front of the existing wall.
Graham
