Hi guys,
Have just seen this setting but I dont understand what it actually controlls.
The setting text is :
Would be nice to get an official explanation for this.
I did read that too. My thoughts - when I read it, were - that it is a setting that lets the device/s keeps the connection to the wifi even when ‘asleep’/in Standby mode.
Meaning making a faster connection possible, when you start using it.
Some times the app takes a while to recognize the devices (that are on wifi) - this could make this process faster.
However, maybe I also am only guessing.
So what you're suggesting is that it's not really the roaming part that is beneficial, but the fact that the B&O product stays connected to Wi-Fi even while in standby mode? This would make sense (assuming that without this feature enabled, it always needs to re-attach when it wakes up - not sure this has been 100% confirmed though...)
bab:So what you're suggesting is that it's not really the roaming part that is beneficial, but the fact that the B&O product stays connected to Wi-Fi even while in standby mode? This would make sense (assuming that without this feature enabled, it always needs to re-attach when it wakes up - not sure this has been 100% confirmed though...)
