Good morning everyone - I wonder if someone could help me.
First off - great forum and I am glad I found it - it has helped me out with another problem that I had !
This problem is to do with one of my Beocom 6000 handsets. I presume these are Mark 1 as I have the black dot on one of the keys and do not have a separate PSTN base station.
The handset can not find the base station. I press dot 7, scroll to register but it just hangs trying to find the station without success. I also press the little button on the base between the contacts to set it to register at the same time of course.
I have replaced the batteries with a new one and still no luck.
OK, so reading threads, it appears that there is a fault with the handset - can someone tell me how much this would cost to fix by an authorised B&O dealer as I see I can purchase a s/hand unit off the dreaded eBay for around £40 ish..
Many thanks in advance for any help - ideally by a dealer of course, unless anyone has any other ideas to try.
Best regards
Luke
PS I have made sure that there is not more handsets registered therefore going over the limit. I am in the UK.
I responded to a similar question a while back, here: http://archivedforum2.beoworld.org/forums/t/1540.aspx
Hope this helps! I decided that a second hand replacement was better than an expensive repair, especially as the latter would need me to upgrade the software in the base station to version 2.5
Thanks for that Guy - I didn't see that post !!
Looks like eBay is the way to go then......
LuckyLuke: Thanks for that Guy - I didn't see that post !! Looks like eBay is the way to go then......
Brengen & Ophalen
Can you tell me more Leslie... ?
