Software BV Avant NG Mk II (75)
This post has 12 Replies | 1 Follower
f5434964
Austria
Posts 206
f5434964 Posted: Sat, Apr 10 2021 6:53 PM
Dear Beoworlders!
I know it is obsolete but...
(Still) Every day my BV Avant NGs (MkII) software does its best to make me cry. I know that B&O will never do another update and I am left alone since the first day of purchase. So if anybody from B&O is reading this – your disregard makes me never thinking of buying a BV again!
Back to my question: did anybody of you get a private solution? Is there a stable software which could made to run on my TV instead of the crappy version of something android?
Best regards
Elmar
andybandy
Posts 164
andybandy replied on Sat, Apr 10 2021 8:40 PM
Hi, Maybe help if you tell what is the issue?
be so exact in the description. Its help :)
beotex
Posts 86
beotex replied on Sat, Apr 10 2021 8:50 PM
Mine was working great until yesterday. Now I get a pop up randomly every few minutes that says “BeoUserLogger has stopped working.” And the PUC isn’t controlling the STB anymore.
Not sure what happened but it’s really annoying all of a sudden. I’ve tried restarting, logging out and back in. May try a reset but don’t want to re-setup everything.
f5434964
Austria
Posts 206
f5434964 replied on Sun, Apr 11 2021 8:16 AM
andybandy:
Dear Andybandy
thats very kind from you...
First: software is slow - ok that’s not a bug...
the apps are crashing regularly- blue box ... is not responding- wait or close;
Once a week the whole system crashes - black screen - android- new start
EPG is not doing fine; channel on sidebar stuck - not moving; going right (future) stucks
arrow up/down: EPG during watching TV (small insert at the top of the screen) does not update
HDD is not found - says that there is no HDD
Playback HDD records: skipping to certain time point not possible
CI: Module not recognised- put out and in or new start works again- by the way: what the hell did they have thought giving two slots which are only working with one card?!?!
best regards
Elmar
andybandy
Posts 164
andybandy replied on Sun, Apr 11 2021 11:43 AM
Hi, it seems this is not only software issue, but seems you have a main board issue. I would contact your local dealer and send in this list to them, and i think you would Get answear change your main board. I was thinking since you have so many big issue it was something like you describe, and i have change another tv main board because of simular issue.. after that is work great again, yes, android base software is slow, but not crash anymore.
So let they change your main board..
andybandy
Posts 164
andybandy replied on Sun, Apr 11 2021 11:47 AM
beotex: You should Reset to factory, if that not work, main board change maybe ? But this is more software issue i think, but if it start to go in to more würst connection it could be a start of defect main board also her. But start to Reset your tv to factory, and Remember to login to Google account and update all the apps, delete apps you can delete and not us.
andybandy
Posts 164
andybandy replied on Sun, Apr 11 2021 11:48 AM
The last post was to beotex
Pat
Posts 152
Pat replied on Mon, Apr 12 2021 10:45 PM
In any of these cases factory reset is a MUST, then set it up again. VERY IMPORTANT : sign in to google via laptop, tablet or mobile. TV doesn’t accept anymore sign in with email and password. All of the Android app must be updated.
If issues still there after few days, Small Signal Board + Big Signal Board have to be replaced. They have to be pre-programmed by B&O in factory for particular serial number. It is the equivalent of Video Engine in Avant mkI, V1 and BV11.
f5434964
Austria
Posts 206
f5434964 replied on Tue, Apr 13 2021 9:56 AM
Dear all!
Thanks a lot for your thoughts and educated tips
Till know I was afraid of a factory reset cause I can remember, that my dealer was not able to set up my satellite reception (I am useing an unicable system); by luck I could do the setup on my own...
It seems that I have to talkt to my dealer... hopefully he will understand my needs (till now he suggested to trade in for a new BV)
Have you any idea how much it would cost to change the main board or the signal boards? Just not to be that much helpless talking to my dealer...
best regards
Elmar
Daniel
Svinarp, Sweden
Posts 1,632
Daniel replied on Tue, Apr 13 2021 8:04 PM
f5434964:
best regards Elmar
Well, I don’t have a 75 Mk II, but a 55 Mk I. Had the DVE replaced last autumn for the fancy price of something like 1500 €. So I would guess it would be the same for yours. Luckily for me, the insurance company took that bullet for me.
beotex
Posts 86
beotex replied on Mon, Apr 19 2021 4:41 PM
Following up on this thread.
A few restarts and an overnight rest seemed to have cleared everything up. Not sure what the issue was, but everything is back working fine. Hopefully, just a random glitch in the matrix Smile
Would be nice, though, to get more functionality from the operating system, but my hopes are just that. Great TV otherwise.
BeoMegaMan
Posts 601
Most of these annoyances can be taken care of by clearing the cache in the Android side of the TV. Clear that and response should return.
Ah, you know... A little B&O here, a little there
f5434964
Austria
Posts 206
f5434964 replied on Sat, Apr 24 2021 10:14 AM
Thanks for all your ideas!
I managed to improve the satellite signal and I think this also helped; a bad signal - could it be a reason?
but: my bad dish signal was caused by a splitter which is needed to feed the twin receiver; now I lost the ability to record....do you know any high quality splitter for a unicable installation? Any idea?
Page 1 of 1 (13 items) | RSS
