Dear Beoworlders!
I know it is obsolete but...
(Still) Every day my BV Avant NGs (MkII) software does its best to make me cry. I know that B&O will never do another update and I am left alone since the first day of purchase. So if anybody from B&O is reading this – your disregard makes me never thinking of buying a BV again!
Back to my question: did anybody of you get a private solution? Is there a stable software which could made to run on my TV instead of the crappy version of something android?
Best regards
Elmar
Hi, Maybe help if you tell what is the issue? be so exact in the description. Its help :)
andybandy: Hi, Maybe help if you tell what is the issue? be so exact in the description. Its help :)
Dear Andybandy
thats very kind from you...
First: software is slow - ok that’s not a bug...
the apps are crashing regularly- blue box ... is not responding- wait or close;
Once a week the whole system crashes - black screen - android- new start
EPG is not doing fine; channel on sidebar stuck - not moving; going right (future) stucks
arrow up/down: EPG during watching TV (small insert at the top of the screen) does not update
HDD is not found - says that there is no HDD
Playback HDD records: skipping to certain time point not possible
CI: Module not recognised- put out and in or new start works again- by the way: what the hell did they have thought giving two slots which are only working with one card?!?!
best regards
Hi, it seems this is not only software issue, but seems you have a main board issue. I would contact your local dealer and send in this list to them, and i think you would Get answear change your main board. I was thinking since you have so many big issue it was something like you describe, and i have change another tv main board because of simular issue.. after that is work great again, yes, android base software is slow, but not crash anymore.
So let they change your main board..
beotex: You should Reset to factory, if that not work, main board change maybe ? But this is more software issue i think, but if it start to go in to more würst connection it could be a start of defect main board also her. But start to Reset your tv to factory, and Remember to login to Google account and update all the apps, delete apps you can delete and not us.
The last post was to beotex
Dear all!
Thanks a lot for your thoughts and educated tips
Till know I was afraid of a factory reset cause I can remember, that my dealer was not able to set up my satellite reception (I am useing an unicable system); by luck I could do the setup on my own...
It seems that I have to talkt to my dealer... hopefully he will understand my needs (till now he suggested to trade in for a new BV)
Have you any idea how much it would cost to change the main board or the signal boards? Just not to be that much helpless talking to my dealer...
best regardsElmar
f5434964: Have you any idea how much it would cost to change the main board or the signal boards? Just not to be that much helpless talking to my dealer... best regards Elmar
Most of these annoyances can be taken care of by clearing the cache in the Android side of the TV. Clear that and response should return.
Ah, you know... A little B&O here, a little there
Thanks for all your ideas!
I managed to improve the satellite signal and I think this also helped; a bad signal - could it be a reason?
but: my bad dish signal was caused by a splitter which is needed to feed the twin receiver; now I lost the ability to record....do you know any high quality splitter for a unicable installation? Any idea?
