Beosound Core & Beolink Passive
This post has 12 Replies | 0 Followers
Abakus2007
Posts 68
Abakus2007 Posted: Sun, Apr 11 2021 9:32 AM
trying to setup outdoor speakers with a beolink passive and a beosound core. Searched and found that I need a special PL cable. Contacted Steve at Sounds Heavenly, unfortunately he can not supply the right cable until this autumnSad. When reading manuals I find that part no. 6271225 should be the one but I've also seen comments that this is not 100% working.
Is there special wiring to get the core and passive to work together?
Any input much appreciated
Baaz
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Apr 11 2021 10:36 AM
You can see the wiring differences at pages 102 and 104 of the Beolink Handbook here: https://beointegration.com/uploaded/EN-BeoLink-handbook-v1-9.pdf
From the diagram, it would appear that the Passive needs the 'Power Up' and 'Overload' connections.
petermc
Australia
Posts 128
petermc replied on Sun, Apr 11 2021 10:45 AM
Hi Baaz,
I had some problems with the passive and the Core. It worked ok but it wasn’t powering on and off when shutting down the Core.
I had outdoor passive speakers attached to a Beolink Passive. Attached to this via Powerlink (Passive) was an Essence 2 (RJ45) with the correct cable (6271225). It all powered up and worked as it should and the Passive turned off when the Essence turns off. All good.
When I replaced the Essence with a Core the Passive would turn on and do its thing however it would not power down when I put the Core into standby. The Passive remained on. I have tested it on 2 Cores and they both did the same thing.
I contacted B&O support and they have replied with the following
'After reviewing the case, we suspect the cause for this behaviour is that the Beosound Essence cuts the 5V on PIN1 when entering standby when the BeoSound Core does not. To fix this, the "old" powerlink plug will need some modification. If you were to cut PIN1 and move the lead on PIN4 to PIN1 instead, this should rectify the issue and restore the system to its previous functionality.
cid:image001.jpg@01D6855B.B5DD5DB0
In short you’ll need a specially modified cable if you want full functionality including on/off.
Peter
Abakus2007
Posts 68
Thanks Peter / Guy,
so I need a somewhat modified 6271225. I'll try to fix a temporary solution until in stock.
Peter, was there supposed to be a picture in Your reply?
Thanks again
Baaz
petermc
Australia
Posts 128
petermc replied on Mon, Apr 12 2021 6:00 AM
Hmmm.
That attachment didn't work.
Will try again
petermc
Australia
Posts 128
This was what B&O sent me regarding the modification
Abakus2007
Posts 68
Thanks Peter,
very helpful. Will try to peel a cord and shift cables.
Baaz
petermc
Australia
Posts 128
petermc replied on Tue, Apr 13 2021 7:02 AM
Good luck Baaz
Let me know how it goes
Peter
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Apr 13 2021 9:47 AM
Abakus2007:
Thanks Peter,
Baaz
Something like this can be very useful if experimenting with connections: https://uk.rs-online.com/web/p/ethernet-couplers/1242520/
Abakus2007
Posts 68
Guy,
that is a neat device, no need for crimping or soldering.  And you can reverse and shift cables.
Baaz
Abakus2007
Posts 68
It worked!
Thank You guys!
had ordered a cable from Bosscom with the right wiring (except yellow and grey) that came today.
Peeled of 5 cm of the outer plastic shield, cut the yellow and grey and soldered the yellow to the grey.
Not very tidy but it will have to do for now.
If someone need a PowerLink/Passive cable(except for Core) in any length it's part no 01349911 (1 m).
Baaz
chucky
Posts 331
chucky replied on Wed, Apr 21 2021 7:31 PM
Abakus2007:
It worked!
Thank You guys!
Baaz
Or just ask steve from sounds heavenly our sponser he has made a lot of cables for me including these...no need to peelBig Smile ships worldwide
ebnrob
UK
Posts 174
ebnrob replied on Thu, Jul 1 2021 11:56 AM
Do you also get a hiss/whoosh noise from the speakers when first turning on? I get this on my essence mk2/passive and the core/passive.
Abakus2007:
It worked!
Thank You guys!
Baaz
Page 1 of 1 (13 items) | RSS
