trying to setup outdoor speakers with a beolink passive and a beosound core. Searched and found that I need a special PL cable. Contacted Steve at Sounds Heavenly, unfortunately he can not supply the right cable until this autumn. When reading manuals I find that part no. 6271225 should be the one but I've also seen comments that this is not 100% working.
Is there special wiring to get the core and passive to work together?
Any input much appreciated
Baaz
You can see the wiring differences at pages 102 and 104 of the Beolink Handbook here: https://beointegration.com/uploaded/EN-BeoLink-handbook-v1-9.pdf
From the diagram, it would appear that the Passive needs the 'Power Up' and 'Overload' connections.
Thanks Peter / Guy,
so I need a somewhat modified 6271225. I'll try to fix a temporary solution until in stock.
Peter, was there supposed to be a picture in Your reply?
Thanks again
Hmmm.
That attachment didn't work.
Will try again
This was what B&O sent me regarding the modification
Thanks Peter,
very helpful. Will try to peel a cord and shift cables.
Abakus2007: Thanks Peter, very helpful. Will try to peel a cord and shift cables. Baaz
Something like this can be very useful if experimenting with connections: https://uk.rs-online.com/web/p/ethernet-couplers/1242520/
Guy,
that is a neat device, no need for crimping or soldering. And you can reverse and shift cables.
It worked!
Thank You guys!
had ordered a cable from Bosscom with the right wiring (except yellow and grey) that came today.
Peeled of 5 cm of the outer plastic shield, cut the yellow and grey and soldered the yellow to the grey.
Not very tidy but it will have to do for now.
If someone need a PowerLink/Passive cable(except for Core) in any length it's part no 01349911 (1 m).
Abakus2007:It worked! Thank You guys! had ordered a cable from Bosscom with the right wiring (except yellow and grey) that came today. Peeled of 5 cm of the outer plastic shield, cut the yellow and grey and soldered the yellow to the grey. Not very tidy but it will have to do for now. If someone need a PowerLink/Passive cable(except for Core) in any length it's part no 01349911 (1 m). Baaz
Do you also get a hiss/whoosh noise from the speakers when first turning on? I get this on my essence mk2/passive and the core/passive.
Abakus2007: It worked! Thank You guys! had ordered a cable from Bosscom with the right wiring (except yellow and grey) that came today. Peeled of 5 cm of the outer plastic shield, cut the yellow and grey and soldered the yellow to the grey. Not very tidy but it will have to do for now. If someone need a PowerLink/Passive cable(except for Core) in any length it's part no 01349911 (1 m). Baaz
