I ripped a commercial CD to my laptop. All of the metadata appears as it should except for the album cover. I ran the ripped CD through the Bliss Music Tagger and was unsuccessful in acquiring the album cover. I was really surprised! I drag-and-dropped the ripped CD to my BeoMaster 5. Everything is fine except the album cover is missing.
I created a .jpg file of the album cover on my PC. Is it possible or does anyone know how to add a .jpg file to the ripped CD so that it shows up on my BeoSound 5? I ripped my CD using Windows Media Player, as I have done in the past. Or am I trying to achieve the impossible? If it is possible, can you explain it in layman's terms....
faithman1_21124:Or am I trying to achieve the impossible? If it is possible, can you explain it in layman's terms....
You need to use a program like MP3tag or EZ Meta Tag Editor. Then you can adjust all meta data embedded in a music file, including the Albumcover.
play around with one off these programs and come back for additional questions
I used the EZ Metadata Tag Editor. I went online and googled for the album cover. Then created a .jpg file of the album cover on my desktop. I used the EZ Metadata Editor to put the album cover with the metadata. IT WORKED!! Thank you so much...
faithman1_21124:I used the EZ Metadata Tag Editor. I went online and googled for the album cover. Then created a .jpg file of the album cover on my desktop. I used the EZ Metadata Editor to put the album cover with the metadata. IT WORKED!! Thank you so much...
Did some of you achieve to have "The Beatles" audio files sorted under artist "B" and not "T" ?
Look at my post HERE to understand what I mean.
With this program, I added all the covers easily and without complications. In addition, you can upgrade already inserted covers to much better quality. size 1000x1000 with no problem.
However, it is important that you have BS5 visible on the network and the MUSIC folder is also visible.
I connected to BS5 on the music folder with my laptop, opened the cover program ( EZ Metadata Tag Editor ) and in an hour I edited everything and modified many.
However, it is necessary to edit album after album, you can't just cover all the albums at once.
