Hi all,
Have a Beogram 3400 type 5703, with a "slow" motor.
Have purchased a servo-controlled motor from Beoparts .( Evidently the old version had an AC motor that is nothing like the newer Beogram 3400 servo -controlled motor.)
Will this servo-controlled motor be able to be fitted ?
Noel.
No,The best solution is to have the original motor rebuilt, cleaned, reoiled etc.
Hi Martin,
Thanks for your response.The turntable had to be repaired (tonearm problem ) ,and the service centre said " Motor is slow at first,but then speeds up after a few minutes. Motor is obsolete and this cannot be improved".
That's why I bought another motor from Beoparts, but now there is doubt that the version I got won't work.
The version I have is the "newer"one i.e.servo-controlled motor- not the older AC motor.
Regards
(I'm fortunate to have a Beogram 2402 to use while I sort out the motor issue for the Beogram 3400.)
