4004 Tone arm wiring disconnected
hammer_smyth
NYC
Posts 29
hammer_smyth Posted: Sun, Apr 25 2021 8:55 PM
Lone time reader and enjoyer of my Beogram 4004, which I acquired in 2010. I've had various small issues over the years and basic repair skills, but need some assistance with a wiring issue.
Two wires (blue and green) in the tone arm have come loose as you can see in the images below. I don't know where to re solder them to.
Any help much appreciated!
H
sonavor
Texas, United States
Posts 3,732
sonavor replied on Mon, Apr 26 2021 2:28 AM
Here is a blog post I made last year of a Beogram 4002 phono cartridge connector replacement.
It shows the wiring you are asking about. The Beogram 4004 is the same as the one I show in the photos.
-sonavor
hammer_smyth
NYC
Posts 29
Thank you so much, this is the underside photo I needed to confirm my guess. Tough soldering assignment ahead, but thank you!
sonavor
Posts 3,732
sonavor replied on Mon, Apr 26 2021 3:45 AM
What I do is remove the tangential arm assembly from the spindle and rails...then turned it upside down to solder.  If you are good with a soldering iron and working from a mirror then doing it in place is possible. I just don't like to risk the hot soldering iron bumping something it shouldn't :-).
Go slowly and careful should be fine though.
Do you know how those two wires came off?  It is very unusual as there is nothing pulling on those wires.
-sonavor
hammer_smyth
NYC
Posts 29
I'm going to try the slow and steady approach with a mirror...wish me luck.
I was hunting for a problem and decided to check the tone arm. I think I pulled it back too far and dislodged these wires, which are shorter than the others. So, an unforced error on my part.
H
Page 1 of 1 (5 items) | RSS
