beocenter 7700 tape question
This post has 7 Replies | 0 Followers
davidosborne436
Posts 37
davidosborne436 Posted: Tue, May 4 2021 7:55 PM
The tape deck on this monster works fine for play and rewind but will not fast forward. I believe there are two belts on this that are both in place so I'm wondering if it's a gearing problem. It's hard to get at as there are so many wires attached so I'm looking for some advice on what to look at to save me tearing it all apart.
Thanks as always
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, May 4 2021 9:21 PM
If you didn't replace the idler wheel rubber parts, I suggest you do that.
Correct parts in beoparts-shop
davidosborne436
Posts 37
martin - thanks. any way to verify if that's the issue? I guess i'm confused as to why it would rewind but not FF
Dillen
Posts 13,191
Dillen replied on Wed, May 5 2021 6:37 AM
All of these drives will need new new belts and idler rubber parts by now. Symptoms can vary a little, but yours are common.
Cleaning off old lubricants and adding fresh will also be needed. This goes for the reel spools in particular.
davidosborne436
Posts 37
any tips on how to extract this so I can get to its innards?
davidosborne436
Posts 37
Dillen
Posts 13,191
Dillen replied on Wed, May 5 2021 5:19 PM
Once you have the Beocenter open in service position, it's merely a matter of three screws and two plugs.
With all due respect, and don't get me wrong, but if you cannot take out the tape drive, you are not the right one to replace the idler rubber parts. It's a bit more involved.
davidosborne436
Posts 37
i understand exactly what you're saying. I figured it out. Now to order parts!
Page 1 of 1 (8 items) | RSS
DigiCert Secured Site Seal
