Beolab Penta and Beolink active.
This post has 3 Replies | 2 Followers
hcs67
Denmark
Posts 7
hcs67 Posted: Wed, May 12 2021 10:09 PM
  Will the display at my Beolab Penta(in link room) work, if I connect them to mainroom, with Beolink Active?
Rgds
Henrik
2 x Beosound 2300, Beosound 3200, Beolab 2500, 2 x Beolab 4000, Beolab Penta mk3.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Henrik,
Yes, if you have a pre-2013 system that supports Datalink (eg. Beosound 9000, Ouverture, etc) and you use fully wired Powerlink mk.2 cables then you will get the data to light up the speaker displays through the Beolink Active:-
https://soundsheavenly.com/powerlink-8-pin-din-connection/23-319-powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores.html#/9-length-18m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
hcs67
Denmark
Posts 7
hcs67 replied on Thu, May 13 2021 8:53 PM
Hi Steve
  Thank you for your answer, I want to use my Beosound 3200(+ Beolab 2500) in kitchen as master.
Currently I’m testing the Beolab Penta in living room with a Beosound 2300, with displays working.
But I would like to make the living room into a link room, to be able to play the same source in both rooms. I just don’t want to loose the display.
Rgds
Henrik
hcs67
Denmark
Posts 7
Hi Steve
Rgds
Henrik
Page 1 of 1 (4 items) | RSS
