Will the display at my Beolab Penta(in link room) work, if I connect them to mainroom, with Beolink Active?
Rgds
Henrik
2 x Beosound 2300, Beosound 3200, Beolab 2500, 2 x Beolab 4000, Beolab Penta mk3.
Hi Henrik,
Yes, if you have a pre-2013 system that supports Datalink (eg. Beosound 9000, Ouverture, etc) and you use fully wired Powerlink mk.2 cables then you will get the data to light up the speaker displays through the Beolink Active:-
https://soundsheavenly.com/powerlink-8-pin-din-connection/23-319-powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores.html#/9-length-18m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Hi Steve
Thank you for your answer, I want to use my Beosound 3200(+ Beolab 2500) in kitchen as master.
Currently I’m testing the Beolab Penta in living room with a Beosound 2300, with displays working.
But I would like to make the living room into a link room, to be able to play the same source in both rooms. I just don’t want to loose the display.
