Hello everyone!
I’m trying to connect my Beo 10-46 to my laptop via HDMI (and to my new Apple TV).
I tried to read the manual but no luck.
Is there anyone that can guide me through?
That should be fairly easy.
However, your problem probably is that you have to configure one of the HDMI ports for it and assign that to a button/a command on the Beo4.
Please reread the Guide, page 11 and onwards:
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/BEOVISION_10/beovision10_guide_english.pdf#page12
I'm really sorry but the guide is not so clear at all and I was trying already before disturbing the community....Beo is amazing but not so user friendly!
I gave up...it's really disappointing to have such nice tv and not being able to connect a simple HDMI input...
Is there anyone else that can provide me some screenshots? Otherwise I have no other chance to call the support
Thanks in advance
The manual that MM linked to should be all the information that you need, and it includes a couple of screenshots of the relevant menus. Just go through slowly and carefully.
Connect your hdmi leads to the TV's input sockets and note the number (AV1, 2, 3 etc) and then refer to the manual, and specifically the CONNECTIONS menu, to set up the corresponding connections.
In the rear pabel I Have two HDMI sockets, how do I know which one is AV1 or 2 or 3 or 4 or 5 or6?
Tthanks
Page 24 of this manual shows hdmi A B or C:
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/BEOVISION_10/beovision10_gettingstarted_english.pdf
Then in the CONNECTIONS menu choose AV2 (assuming nothing is connected to SCART socket AV2), call the source V.MEM, then scroll down to HDMI, and choose the corresponding input A B or C.
Once stored, you should be able to select that hdmi input using V.MEM on the remote.
(EDIT: Not all models have hdmi input C, so yours probably just has A and B)
