morning all,
Does anyone have the pinout diagram for the BV 10-46 motorized stand socket. I would like to put the 10-46 on a 7-40 stand.
regards
John
I tried to post a snapshot but it doesn't appear to be working - will try again later!
EDIT: Here you go:
Thanks Guy,
been a bit busy so just checked and found your 2nd reply, I appreciate this, By the way , this is looking at the rear of the tv isn’t it?
Jondob:By the way , this is looking at the rear of the tv isn’t it?
If it's consistent with the SCART pinout diagram in the same manual, then it's looking at the solder side of the socket - i.e looking 'out' of the TV, or into the plug.
But to be on the safe side I would check pins 1 and 5 with a multimeter.
I'll try it this weekend and let you know
thanks again
