BV Motorized Stands
Jondob
Posts 4
Jondob Posted: Tue, May 18 2021 10:05 AM
morning all,
Does anyone have the pinout diagram for the BV 10-46 motorized stand socket. I would like to put the 10-46 on a 7-40 stand.
regards
John
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, May 18 2021 10:38 AM
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, May 18 2021 10:43 AM
I tried to post a snapshot but it doesn't appear to be working - will try again later!
EDIT: Here you go:
Jondob
Posts 4
Jondob replied on Mon, May 24 2021 8:01 PM
Thanks Guy,
been a bit busy so just checked and found your 2nd reply, I appreciate this, By the way , this is  looking at the rear of the tv isn’t it?
regards
John
Jondob
Posts 4
Thanks Guy,
regards
John
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, May 24 2021 8:45 PM
Jondob:
If it's consistent with the SCART pinout diagram in the same manual, then it's looking at the solder side of the socket - i.e looking 'out' of the TV, or into the plug.
But to be on the safe side I would check pins 1 and 5 with a multimeter.
Jondob
Posts 4
Jondob replied on Tue, May 25 2021 1:21 PM
I'll try it this weekend and let you know
thanks again
Page 1 of 1 (7 items) | RSS
DigiCert Secured Site Seal
