Beocentre 6-23
This post has 9 Replies | 2 Followers
Bestmi52
Posts 5
Bestmi52 Posted: Sun, May 23 2021 6:32 AM
Hi guys,
My computer monitor broke yesterday and the only thing i have to use until it comes back
From. Repiars is a.
B&O beocentre 6-23 this has a dvi input .
I've connected all leads to it but unfortunately i am unable to get it to show dvi menu.
It been Stored correctly and used as an information screen before using dvi connection
But now doesn't pickup signal through dvi socket.
Any help will be appreciated as i need this up and running asap
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, May 23 2021 7:12 AM
Good morning and welcome to Beoworld!
You should be able to select the DVI input by pressing PC on the remote. If your remote is a Beo4, the PC may be one of the options under the LIST function. If not, you can add it.
Bestmi52
Posts 5
Bestmi52 replied on Sun, May 23 2021 7:23 AM
Unfortunately i can't find original remote that came with the tv.
Having to use a third party remote made to replce original remote.
Has full function as original remote but PC and dvi menus dont show.
So no way to select dvi/pc input
When i last used it , automatically picked up signal and showed menu and was able to select input using abovementioned remote
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, May 23 2021 7:31 AM
On the BL1000 remote you could select PC by pressing SHIFT then STORE. Does your third party remote have those buttons?
Bestmi52
Posts 5
Bestmi52 replied on Sun, May 23 2021 7:35 AM
Yes it does I'll try that and get back to you
Bestmi52
Posts 5
Bestmi52 replied on Mon, May 24 2021 3:03 PM
Ok ive tried everything
I'm waiting from the company who made this remote
It would seem operating the tv with it is sporadic at best.
I know it worked before but only brings up basic connection menu and pc is not listed.
And with no physical buttons on the tv makes getting dvi
To show is difficult.
The manufacturer of the remote reassured me that
This is a replacement for the BO04 remote that came with the tv.
So maybe the remote has develpoed a fault.
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, May 24 2021 5:29 PM
In that case you may be better to look for a second hand BL1000 or Beo4 remote.  These can usually be found for about £30 upwards, depending on condition.
Stoobietoo
Exeter, Devon, UK
Posts 692
The user manual says it only accepts the following resolutions so you may find if the PC isn't  set to one of those, it may not show.
60 Hz;
640×480, 800×600, 1024×768, 1366×768
Stoobie
Bestmi52
Posts 5
Bestmi52 replied on Tue, May 25 2021 4:17 AM
I've made sure the settings are correct
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, May 25 2021 9:02 AM
My BC6-23 is back in its box at the moment so I can't check, but as far as I remember, the PC/DVI input does not 'show' in any menus.  It is simply selected directly using the elusive PC command.
(EDIT: See pages 5 and 37 of the Reference Book here: https://support.bang-olufsen.com/hc/en-us/articles/360041518692)
Also, I am slightly confused that the TV ever 'automatically picked up signal and showed menu' as stated in an earlier post.  I don't think that there is any 'auto-detect' switching to the DVI input, unless perhaps the TV was a modified version used in a hotel.
Page 1 of 1 (10 items) | RSS
