BeoGram 1000/1500: needle to record distance, how to adjust?
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER Posted: Fri, May 28 2021 2:05 PM
Working on a BeoGram 1500, I just found out that the distance between the needle tip and the vinyl, is about 2 mm. With the current record I am playing, that's fine. But if a have another (wobbly) record, it will touch the groove when it shouldn't.
So I am looking for:
  1. The proper distance between needle tip and record; how much should that be?
  2. How to adjust the tone arm/arm lift to the right height?
Ad 2. For the tone arm itself I have seen that on the pivot point, it has a nut on the bottom side. For the arm lift I am not sure if I can change the height. So should I adjust the height of both the tone arm and the arm rest? How should I do that?
Søren Mexico
Mexico City
Posts 6,411
Søren Mexico
Mexico City
Posts 6,411
Get yourself a manual, free for silver and gold members
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
