Hey everyone, did you know that you will soon be able to stereo pair two Emerge speakers directly in the B&O app? A new software update which launches very soon will make this possible without needing to use Chromecast - thanks for listening to my request B&O! I will release a video with full details as soon as this update is rolled out...watch this space!
Steve.
www.soundsheavenly.com
Not yet, but I am now planning to buy a second Emerge for this, as I would love to be able to play them in stereo.
I will update you once I have got this tested!
Kind regards, Steve.
Is it a SW update or an app update? Haven’t seen a new version of the app in the App Store. My dealer told me the launch of the feature has been pushed back a bit (it is called Speaker Link, right?).
Hi 1990,
There have been both software and app updates in the past day or so, not sure which one triggered the change but it is a very welcome update. This is just what is needed to sell a second Emerge to many owners of a single speaker!
Kind regards Steve.
Definitely a sw upgrade of the little speaker - and an app update in order to make it happen....if you have 2 of them.
Wondering if that is done using the same technology, that also works in the BL28 (LC3plus from Fraunhofer)....probably is.
in that case the BS Balance should be up next, I guess.
And the Level!
Amazing news!
It would also be great to have some confirmation on what sources support stereo playing if the speakers are stereo-paired with the B&O app rather than with Google Home (in which case, it only supports Chromecast as an input, please correct me if I'm wrong).
I'm just waiting for the opportunity to test this, I think it should work for all sources, but I will report back asap once I have checked.
Steve at Sounds Heavenly:Hi, I'm just waiting for the opportunity to test this, I think it should work for all sources, but I will report back asap once I have checked. Kind regards, Steve.
I expect this feature is also in the Level available
Hi Steve. Witch version off the B&O app you have? Because we have Get information that this update should come 31/5 but have Been postponed because off some issue.
so Wonder witch version you have Get off the app to Get this work.
andybandy: Hi Steve. Witch version off the B&O app you have? Because we have Get information that this update should come 31/5 but have Been postponed because off some issue. so Wonder witch version you have Get off the app to Get this work.
Strange.. her its only 3.14.0.37144 and that is test software.
do you have a test software? Or is this release in UK?
I read the sw wrong. Seems i have a newer version.
then i will test stereo pair tomorrow :)
Great news Steve and thanks for posting.
What happens if you try to un-pair (separate) them?
I tried this feature (not through the app) but the hard press of buttons on the A1 to pair them. And when i tried to use them independently, it would always look for the second one and it would get confused.
Even factory resetting them hasn't made them the same ever again.
It might be diff technology but the principle is the same.
andybandy:Strange.. her its only 3.14.0.37144 and that is test software. do you have a test software? Or is this release in UK?
Carolpa: andybandy:Strange.. her its only 3.14.0.37144 and that is test software. do you have a test software? Or is this release in UK? this version as well. The picture was actually made in this version (because of language).
actually the latest build beta version doesn't show this feature! roll back to the previous build and it will show.
steve1977:Is this the long awaited new mozart feature?
Its a feature that is only implemented on the products using the Mozart platform as I understand it.
steve1977: Any hope to see this on non-mozart speakers like the BS1 or is this a hardware limitation?
For this feature Mozart platform is required. So I guess the answer is no.
steve1977: Just stereo pairing or also surround pairing?
As of now only stereo, since its only involve stereosource. I heard rumors that Eclipse and Harmony will get possibility to use devices on the Mozart platform as regular speaker. In a surround setup I assume.
steve1977: Is the only way to play to the group through the b&o app (which makes sources very limited) or also via AP / CC?
Not sure. Lets see when Steve have tested
steve1977:I Possible to join the pair via “touch to join”? Or via an essence remote?
Touch to join is not present on the Mozart platform.
steve1977:I Can the stage be paired as center for a 3.0, 3.1 or 5.1 setup?
No
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hi everyone,
Just to clarify that I updated my iOS devices to the latest app version in the Apple store and my Emerge is running software 1.6.24053
This may not be on general release yet, as further updates are still being rolled out. It will go live across the "Mozart" speakers (Emerge, Level and Balance) in the coming weeks for stereo pairing within the B&O app.
Further details to follow once I can test two speakers in stereo...
Carolpa:Let one BS1 play the left channel and the other the right channel.
(Or are you saying that this is how B&O *would/could/should* accomplish this? I.e. for all ASE 2 gen devices, implement a new "balance" slider which, rather than manipulating sounds coming out of the speaker (BS1) / speakers (BS2), manipulates the incoming signal, e.g. for the BS1 so the stereo-to-mono mix-down is turned off?)
trackbeo:And one does that how, exactly? (Or are you saying that this is how B&O *would/could/should* accomplish this? I.e. for all ASE 2 gen devices, implement a new "balance" slider which, rather than manipulating sounds coming out of the speaker (BS1) / speakers (BS2), manipulates the incoming signal, e.g. for the BS1 so the stereo-to-mono mix-down is turned off?)
