Apple Music just launched Dolby Atmos. You can listen to spatial audio with Dolby Atmos devices.
My question is:
Would spatial audio work with the Beoplay Portal?
From the description it says that it should work with Xbox and PC (I have a Mac Mini).
Yes, there is a difference between the spatial audio Apple provides for movies and music.
For music, it works with any headphones.
For movies, it requires the AirPods (and maybe certain Beats?) headphones.
Thanks @sandyb and @leosgonewild for your tips. I just bought the Beoplay Portal. I don't have Xbox, but I still think you can use this as a normal bluetooth headphone set. I will test and compare it with my Beoplay H95.
How did it work? I am thinking of buying but want to make sure dolby atmos is available for music and/or movies. Thnx
