Beoplay Portal with Dolby Atmos?
This post has 4 Replies | 0 Followers
Baard Hansen
Norway
Posts 6
Baard Hansen Posted: Fri, Jun 11 2021 2:34 PM
Apple Music just launched Dolby Atmos. You can listen to spatial audio with Dolby Atmos devices.
My question is:
Would spatial audio work with the Beoplay Portal?
From the description it says that it should work with Xbox and PC (I have a Mac Mini).
leosgonewild
Helsinki, Finland
Posts 2,373
Spatial Audio should work with all BT headphones as long as it is set to “always on” in Settings-Music-Audio-Dolby Atmos
Sandyb
Posts 2,186
Sandyb replied on Fri, Jun 11 2021 5:12 PM
Yes, there is a difference between the spatial audio Apple provides for movies and music.
For music, it works with any headphones.
For movies, it requires the AirPods (and maybe certain Beats?) headphones.
Baard Hansen
Norway
Posts 6
Thanks @sandyb and @leosgonewild for your tips. I just bought the Beoplay Portal. I don't have Xbox, but I still think you can use this as a normal bluetooth headphone set. I will test and compare it with my Beoplay H95.
chatter94065
Posts 1
How did it work? I am thinking of buying but want to make sure dolby atmos is available for music and/or movies. Thnx
Page 1 of 1 (5 items) | RSS
