And restarting the wifi router did not help either?
Millemissen:And restarting the wifi router did not help either? MM There is a tv - and there is a BV.
I know it sounds weird but try to unplug every BO multiroom product from mains, wait 60 seconds then plug them all back.
I noticed the same issue with my BeoSound Core. When it happens, the music starts with a “fade-in” effect for the first 3 seconds.
If I play a 24/192 flac over local DLNA, the delay is even bigger, around 5-7 seconds.
Neither rebooting the BS Core, the router or DLNA server works to solve the delay.
Only unplugging the Core from the mains solves the issue for me.
In my case, I think the delay happens after I (rarely) change the Bass/Treble sliders in the BO App.
Cheers!
pig30n:I noticed the same issue with my BeoSound Core. When it happens, the music starts with a “fade-in” effect for the first 3 seconds.
Glad to read this, I noticed this behavior too following the latest Core software update, and I like it to be honest. Another new hidden feature.
I raised it in this forum but had nobody confirming.
I missed your forum post about this. Indeed, I first noticed the problem a few months ago, coinciding with the last Core software update.
I don't think it's a hidden feature :). Most probably a bug.
pig30n:I don't think it's a hidden feature :). Most probably a bug.
A nice bug then IMHO as often volume levels are not the same across sources, fade in when changing a source makes the transition smoother.
This is something I would like on other products, as an option for example, particularly on my BS1 which wakes me up every morning with a radio channel, fade-in would make a smoother awakening !
Aussie Michael:I tried playing around with the network delay to test and the settings are as they always are
What value do you currently have for WiFi delay?
I had similar issues, smaller sync delay though, between my M3 and my Moment and the only way I managed to recover temporarily was to change the WiFi delay to force resync between products.
Do you have a WiFi mesh network?
mbolo01: Aussie Michael:I tried playing around with the network delay to test and the settings are as they always are What value do you currently have for WiFi delay? I had similar issues, smaller sync delay though, between my M3 and my Moment and the only way I managed to recover temporarily was to change the WiFi delay to force resync between products. Do you have a WiFi mesh network?
Hi
wifi msec 200, which is what it has been in the past when working in sync and now when not in sync.
I also tried changing this to 50 and 30 and that didn't help, it remains out of sync
wired is 50 msec, but there is no wired products, only the avant and BV14
Aussie Michael:wifi msec 200, which is what it has been in the past when working in sync and now when not in sync.
mbolo01:Have you tried values >= to 1000 ms? BS Moment, BS Core, BG 4002, BC 4500, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
LOL. Old tricks never get old :).
Glad I’m not the only one with this problem and the solution works for you too.
It’s probably a bug in the BO App combined with recent products firmwares.
Aussie Michael:I now have 200 wired and 200 wireless and that works too.
CB:Wow Michael ! that's a hell of a lot of B&O devices
