Beolink 7000 and Beocenter 9500
This post has 4 Replies | 0 Followers
armandc1
Posts 16
armandc1 Posted: Wed, Jun 16 2021 8:14 PM
Hi everyone!
So I finally got my BL7000 working, however I have one question. I get two way communication as it should, except I do not get an indication of volume level on the red display. Does 9500 communicate volume level to the BL7000 or is that something only the Beosystem 7000 is capable of doing?
Thanks, Armand.
lawrencejmcook
Posts 742
Hi Armand,
You should get volume display (I also used this combination, now packed away).
Lawrence
trackbeo
Posts 644
trackbeo replied on Thu, Jun 17 2021 12:09 AM
Not only is my 9500's status data, including volume, transmitted to my Beolink 7000, but if I press buttons on the 9500's display/keypad instead of the remote, the remote turns itself off instantly.  (Note: my remote was configured initially by adding components to a 7000 system, so the fact that it controls and receives data from the 9500 when in that room is incidental.  I do not know its behavior if you configure the remote while it's talking to a 9500 initially.)
Bill Briscoe
Chicago, IL USA
Posts 165
I've always thought that having volume status show on the BL7000 was an indication that two way was working. No volume = no two way.  I have 3 BL7000s that all work with my BM7000, all show volume.
I'm sure there are other ways to verify two way if you search the forum.
good luck,
Bill
armandc1
Posts 16
armandc1 replied on Thu, Jun 17 2021 3:24 AM
Thanks for responding!
I got it working, turns out I just needed to re program the components. I don’t know why but that fixed everything, HmmI have full two way functionality now!
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
