My BeoSound 1 has been working fine but 24 hrs ago started flashing red and B&O app tells me: This product is not available on the current network. When I check my ISP the device does appear as connected via wifi. I see red flashing means battery below 2% and/or 'hardware error'. The device is plugged into power. What should I do?
That has happened to my BS1 as well.
Try to turn off power and then power on again.
My Beosound 1 is unresponsive, what can I do? – Bang & Olufsen Support (bang-olufsen.com)
If still problems, do a factory reset.
How do I reset Beosound 1 and remove all paired Bluetooth devices? – Bang & Olufsen Support (bang-olufsen.com)
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Thanks for your help! Reset worked.
Good to hear
