BeoSound 1 flashing red and app not detecting it
margaret3717
Posts 3
margaret3717 Posted: Sat, Jun 26 2021 10:16 AM
My BeoSound 1 has been working fine but 24 hrs ago started flashing red and B&O app tells me: This product is not available on the current network. When I check my ISP the device does appear as connected via wifi. I see red flashing means battery below 2% and/or 'hardware error'. The device is plugged into power. What should I do?
Hiort
Sweden
Posts 2,895
Hiort replied on Sat, Jun 26 2021 12:50 PM
That has happened to my BS1 as well.
Try to turn off power and then power on again.
My Beosound 1 is unresponsive, what can I do? – Bang & Olufsen Support (bang-olufsen.com)
If still problems, do a factory reset.
How do I reset Beosound 1 and remove all paired Bluetooth devices? – Bang & Olufsen Support (bang-olufsen.com)
margaret3717
Posts 3
Thanks for your help! Reset worked. Big Smile
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Jun 27 2021 9:19 AM
Good to hear Smile
Page 1 of 1 (4 items) | RSS
