Hello all,
I'm struggling to find the smaller bracket that mounts to the wall (I have the larger piece that mounts to the back of the unit)
Does anybody know of where I can get hold of one of these, or even better have one they would like to sell me? I have read that it is possible to hang the unit directly from screws in the wall but I would much rather mount it properly.
Thanks!
Jon (UK)
To be fair I'm struggling to see why I couldn't use something like this assuming the size matches and they are very securely mounted.https://www.ebay.co.uk/itm/303430286771
Try stb brackets. They have them.
I made it my selfe..in 20 minutes...i use 2.5mm steel plate..cut it in shape end bend it ..on the end spay silver...fit's perfect.
