BeoSound 9000 Vertical Bracket - Smaller Piece
jkhamler
Posts 286
jkhamler Posted: Mon, Jun 28 2021 11:00 AM
Hello all,
I'm struggling to find the smaller bracket that mounts to the wall (I have the larger piece that mounts to the back of the unit)
Does anybody know of where I can get hold of one of these, or even better have one they would like to sell me? I have read that it is possible to hang the unit directly from screws in the wall but I would much rather mount it properly.
Thanks!
Jon (UK)
jkhamler
Posts 286
jkhamler replied on Mon, Jun 28 2021 11:06 AM
To be fair I'm struggling to see why I couldn't use something like this assuming the size matches and they are very securely mounted.
https://www.ebay.co.uk/itm/303430286771
Teyelvis
Posts 49
Teyelvis replied on Mon, Jun 28 2021 1:11 PM
Try stb brackets. They have them.
marexy
Posts 710
marexy replied on Mon, Jun 28 2021 8:44 PM
I made it my selfe..in 20 minutes...i use 2.5mm steel plate..cut it in shape end bend it ..on the end  spay silver...fit's perfect.
Page 1 of 1 (4 items) | RSS
