Hi everyone,
This is my first post, and am hoping someone can help me with what is hopefully a simple connection question.
I would like to connect a BeoSound 3000 into a BeoVision Avant 55NG so that it can play through the various surround sound speakers. I have the NL/ML BeoLink convertor but lost as to how I connect this as there are so many options, and am struggling to make sense of the manual or any links online.
Master Link (?) from BeoSound into NL/ML is ok as there is only one option, but is it then r45 to TV, and if so, into and from which connection options?
Any help really appreciated, and apologies if this is an obvious question/answer.
Tom
Eclipse 65V1-32Beosound M5Essence MK2BLI
Hi Seanie, thank you for replying.
It's not connected to the TV at the moment as wasnt sure where to connect, and was running out of plugs.
Does this mean I need to connect the NL/ML into a router and not the TV? Makes sense as I had never realised that NL meant Linked to the Network!
Thank you so much - think this could be the answer.
Just need to figure a way to connect it now... maybe via tp-link
Connection:
1. BS3000 - ML connect to - BLC (Beolink converter NL/ML) - LAN connect to your network
2. BV Avant - preferabel LAN connect to the same Network as your BLC (otherwise use WiFi)
Setup:
Open setup of the BLC (B&o app beter easier on a Mac/PC).
I presume you have all the speakers connected to the Avant.
Goto tab: Configuration, sub tab Settings:
1. check ML enabled
2. ML-role = V Master
3. Confirm with Save (do this with every change, otherwise the settings may not be changed)
4. Goto sub tab Experience mapped to NL
5. enable/check the sources of the BS3000 (CD, Radio, Aux). Note: you can rename the sources to, for example, CD3000, AUX3000, etc.
6. Confirm with Save
How to Play CD/Radio/Aux
1. open B&o app
2. add the BLC (only the first time needed)
3. goto Home
4. choose BLC
5. tab the BLC name on the black stroke (left below on the app)
6 choose "..."
7. select your source (Radio/cd/aux), the source should start to play
8. when play, select "multiroom" (the two rectangles)
9. add the Avant
10. point 8 and 9 can be replaced, by selecting JOIN on your Beoremote One
Razlaw:That should be possible, correct? In the Masterlink settings of the converter I have set DVD and DVD2 to control Music and TuneIn from the Core. I am very new at this, less than 24 hours.
Razlaw:I have been trying to get it set up. I have an Essence, V1, Core, and M5. On the Masterlink side I have a BV10, BV7, BS3000, BS5, and an active kit.
You should, instead of DVD/DVD2, use ML sources not physically available (PC or V.AUX2).
Note: because your BS5 in combo with a BS3000, you can not set the ML role to Source Center. Then the NL sources could be programmed as N.Radio/N.Music in the ML side of the system; and because of the BS3000 the CD/Radio command can't be used..
The solution to this issue would be introducing a second BLC.
Razlaw:Thanks! My BV7 does not have the built in DVD player. I will try other commands as you suggest. Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
Carolpa: Did you program the IR mapping correctly?
Carolpa is correct.
Carolpa: Razlaw: Thanks! My BV7 does not have the built in DVD player. I will try other commands as you suggest. Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5 than DVD should work one would say Did you program the IR mapping correctly?
Razlaw:DVD did work in the room with the Active Kit. Now have a much more major problem. All of the settings seem to be the same to me, but must not be…LOL. The BS3000 and BS5 will now not turn on..If I try to use CD as a source via NetLink on the V1…..the V1 displays CD but the 3000 does not turn on. Even if I sit in the same room as the 3000, 10 and 5, they will not turn on using the BR1. The BV10 also will turn on.
2. You have to free audio sources to work, but almost all are used
3. Try using A.Mem
My integration of ML in NL:
1. The system is completely NL based
2. BSys 7000 is connected using a T1611 to a BLC and primary linked to my BV11
3. BS9000 BLC connected (ASlave: primary linked to Shape)
4. BS3000 BLC connected (ASlave: primary linked to BS35)
So I can start a ML audio source locally as a source of a NL device and Join it on all my NL devices.
This way you will not be limited by ML sources available.
Carolpa:Thinking about your system, the trick using video sources for audio sources won’t work 100% correctly. 1. The BV10 or BV7 doesn’t have a source programmed as DVD? 2. You have to free audio sources to work, but almost all are used 3. Try using A.Mem
Razlaw:
a. your ML are all linked? Audio and Video Masters are? How is the BS5 integrated; which commands start N.Music/N.Radio in the BS5.
b. the settings of the BLC? please make additional pictures.
Carolpa:2 questions:a. your ML are all linked? Audio and Video Masters are? How is the BS5 integrated; which commands start N.Music/N.Radio in the BS5. BV 10 and BS3000 are masters.b. the settings of the BLC? please make additional pictures.
Razlaw:Couple more pictures….everything works fine playing ML sources to NL products.
Razlaw: Carolpa: 2 questions: a. your ML are all linked? Audio and Video Masters are? How is the BS5 integrated; which commands start N.Music/N.Radio in the BS5. BV 10 and BS3000 are masters. b. the settings of the BLC? please make additional pictures. Yes, BV7, BV10, Beolink Active, BS3000, BS5 all connected by Masterlink and controlled with N Music and N Radio Commands. This morning I tried the PC and DVD commands on the Active. It did turn the speakers on but no sound. Interestingly is the Essence if turned on, the PC and DVD commands to the Active turn the Essence off. Thank you so much for your help!
2 questions:
Carolpa:the ML role is set to V Master, but note on ML side you already have a A.Master. This will introduce trouble in your setup!
Carolpa:Goto Home in the app. Choose the Beolink Converter NL/ML. Open multiroom (two rectangles). Join the Essence. Sound?
Carolpa:Sorry, I didn’t pay attention. The problem is NL sources to be heard on ML. So how are the sources set on the tab “Sources visible on ML”.
What happens when you map a NL-source to eg CAMERA?
1990:What happens when you map a NL-source to eg CAMERA?
BeoTalk Willie might have some ideas over on YouTube
1990:BeoTalk Willie might have some ideas over on YouTube
