BEOMASTER 7000 - 5 pin ??
Lovejoy
Posts 12
Lovejoy Posted: Fri, Feb 15 2013 10:35 AM
Hey
on my 2 Beomasters 7000 there is an about 4 cm cable with a 5 pin socket that comes out of the beomaster. It is located over the plug for FM antenna. What is that for?
greeez
stefan
200 miles from Struer
Posts 2,920
stefan replied on Fri, Feb 15 2013 1:52 PM
The preamp out - poweramp in insertion socket? Should be covered with a plastique plug to connect ins - outs.
Stefan
Lovejoy
Posts 12
Lovejoy replied on Fri, Feb 15 2013 2:40 PM
Hey
no no the cable comes out about 4cm of the beomaster 7000 just near the antenna plugs. On the calbe is written "low voltage 30" and on the cable is a 5 pin-socket.  Here 2 pics of it
http://archivedforum2.beoworld.org/media/p/43719.aspx
http://archivedforum2.beoworld.org/media/p/43718.aspx
BayernTechnik
Germany
Posts 291
Hmm, well I think that's for an extra Beomaster 7000 infrared receiver ...
Langleyav
Windsor UK
Posts 226
Langleyav replied on Fri, Feb 15 2013 3:48 PM
That looks like an unauthorised modification to the receiver, possibly to control some external device. I did a similar mod to my 7000 receiver in order to automatically power on an external equilizer on the pre-amp out/ power-amp in socket whenever the receiver was switched on
Ron
Søren Mexico
Mexico City
Posts 6,411
Langleyav:
Ron
Ron may be right, but better open up and check where it is connected, you never know Surprise
Page 1 of 1 (6 items) | RSS
DigiCert Secured Site Seal
