Beosystem 7000 to Beolab 2000 - MCL or Datalink
Lovejoy
Posts 12
Lovejoy Posted: Fri, Feb 15 2013 10:47 AM
Hey
i would like to connect a meolab 2000 to a beomaster 7000. Some say i need a beolink converter 1611 and connect it to AUX and powerlink --- other say i need ML/MCL converter 1651 which i can connect to SPEAKERS 2 MCL left and right. What shall i do?
By the way , i have this strange cable (on the right of the picture for the SPEAKERS 2 MCL left and right  http://www.beoworld.org/beotech/mcl/mcl2-p10.htm): what is that for??
greeez
Johan
Uppsala, Sweden
Posts 239
Silver Member
Johan replied on Fri, Feb 15 2013 12:49 PM
I think you can do it either way, but the 1611 is probably easier and better (and cheaper). It operates at line-level. If you'd go for the ML/MCL converter the BM7000 amplifies the signal to speaker level and then the converter attenuates it to "line-level".
I'd definitely go for 1611 connected to AUX on BM7000 and then connect the 1611 to the BL2000 with an ML cable.
/  Johan
stefan
200 miles from Struer
Posts 2,920
stefan replied on Fri, Feb 15 2013 1:45 PM
1651 ML/MCL converter is meant to connect a (newer) ML device like BS9000, BS4... to an existing MCL distribution with MCL boxes and passive speakers in link rooms. It has a built in amplifier.
You need a BL converter 1611 to make your BM7000 Masterlink compatible. BL2000 is an active link room system with Masterlink. You won`t need an extra amplifier.
Stefan
Lovejoy
Posts 12
Lovejoy replied on Fri, Feb 15 2013 1:57 PM
Thanks for your answer Johan.
but i would also need to connect POWERLINK from BM 7000 to 1611?
http://beophile.com/?page_id=882
Greeezz
lovejoy
Johan
Uppsala, Sweden
Posts 239
Silver Member
Johan replied on Fri, Feb 15 2013 2:01 PM
No, PL is 8 pin cable for connecting Beolab speakers. You need an 7 pin datalink cable between 1611 and BM 7000.
/  Johan
stefan
Posts 2,920
stefan replied on Fri, Feb 15 2013 2:09 PM
Lovejoy:
Greeezz
lovejoy
Correct. In some constellations you will need a Powerlink cable from BM7000 to BL converter in addition to 7 pin Audio Aux Link cable.
It´s mainly to let a connected Masterlink videomaster detect whether the audiomaster (BM7000) is powered on or not.
I don`t think you will need it with a BL2000....(?)
Stefan
Johan
Uppsala, Sweden
Posts 239
Silver Member
Johan replied on Fri, Feb 15 2013 2:17 PM
stefan:
No you don't. I had exactly this setup. Audio aux cable (7 pin) from BM to 1611, ML cable from 1611 to BL2000. Works perfectly.
/  Johan
Lovejoy
Posts 12
Lovejoy replied on Fri, Feb 15 2013 3:06 PM
Cool thanks for your answer
Does sb know about the 2 versions of the converter? Is there a difference as indicated?
"This requires the Converter to be of the newer type : 1161166. the older 1161466 is unable to perform this function."  http://www.beoworld.org/prod_details.asp?pid=983
Johan
Uppsala, Sweden
Posts 239
Silver Member
Johan replied on Fri, Feb 15 2013 4:46 PM
I think you need the 1161166 version for this.
/  Johan
Page 1 of 1 (9 items) | RSS
DigiCert Secured Site Seal
