Hi All,
I have a beomaster 1001, but the left channel is very distorted. any ideas on what can cause this. i have swapped speakers to ensure the speakers i am using are good.. same porblem left channel still very distorted.
any help will be appreciated,
Hi Heinwil1,
Got the same issue which ended up in a silent channel.
I checked the volume slider after an advice from from one of this forum specialist. he was fine.
Next advice was full recap and it's now pending.
Maybe you'll be luckier.
thanks, hopefully not but will keep you posted
Regards
Hein
It's 45+ years old.It will definitely need a recap.
The distortion could come from bad capacitors, but could also be a bad output stage transistor or something else.
Connect a signal generator to the Tape input and send in a 1KHz sine.Put a scope to the input signal to the amplifier and see, if the output stage is fed a clean or a distorted signal.If the input is clean the fault is in the output stage.
