Left speaker channel - beomaster 1001
Heinwil1
Posts 9
Heinwil1 Posted: Sat, Jul 10 2021 7:59 PM
Hi All,
I have a beomaster 1001, but the left channel is very distorted. any ideas on what can cause this. i have swapped speakers to ensure the speakers i am using are good.. same porblem left channel still very distorted.
any help will be appreciated,
matador43
Posts 1,373
matador43 replied on Sun, Jul 11 2021 10:16 AM
Hi Heinwil1,
Got the same issue which ended up in a silent channel.
I checked the volume slider after an advice from from one of this forum specialist. he was fine.
Next advice was full recap and it's now pending.
Maybe you'll be luckier.
Heinwil1
Posts 9
Heinwil1 replied on Wed, Jul 14 2021 1:04 PM
thanks, hopefully not but will keep you posted
Regards
Hein
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Jul 14 2021 1:37 PM
It's 45+ years old.
It will definitely need a recap.
The distortion could come from bad capacitors, but could also be a bad output stage transistor or something else.
Connect a signal generator to the Tape input and send in a 1KHz sine.
Put a scope to the input signal to the amplifier and see, if the output stage is fed a clean or a distorted signal.
If the input is clean the fault is in the output stage.
Page 1 of 1 (4 items) | RSS
