Hi All,
Please can someone assist, I want to make a DIN to RCA cable to connect into my Beogram 1001. Please can someone assist with a pin connection layout - for phono and the tape output.
Regards
Hein
Heinwil1: Hi All, Please can someone assist, I want to make a DIN to RCA cable to connect into my Beogram 1001. Please can someone assist with a pin connection layout - for phono and the tape output. Regards Hein
Connect INTO your Beogram 1001?The DIN pinout is standard. You can look it up in detail in the schematics in the servicemanual,- but where did the RCAs come from? Both Beomaster 1001 and Beogram 1001 have DIN. They are made for eachother and should plug directly together.
Hi Dillen,
Only reason for the converstion is that i am connecting another turntable and tape, as the Beogram I have is completely broken - got it as a give away from someone.
So I would like to convert the DIN's and speaker outlets to RCA's, as i also cannot find any of the old speaker plugs.
Thanks for your response
I would very much advice against converting speaker outputs to RCA.The risk of shorting the outputs are to high.
DIN plugs are easily found on f.e. Ebay:
speaker din plug | eBay
