Beomaster 1001 DIN to RCA
Heinwil1
Posts 9
Heinwil1 Posted: Mon, Jul 12 2021 10:12 AM
Hi All,
Please can someone assist, I want to make a DIN to RCA cable to connect into my Beogram 1001. Please can someone assist with a pin connection layout - for phono and the tape output.
Regards
Hein
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Jul 12 2021 11:34 AM
Heinwil1:
Hi All,
Regards
Hein
Connect INTO your Beogram 1001?
The DIN pinout is standard. You can look it up in detail in the schematics in the servicemanual,
- but where did the RCAs come from? Both Beomaster 1001 and Beogram 1001 have DIN. They are made for eachother and should plug directly together.
Heinwil1
Posts 9
Heinwil1 replied on Mon, Jul 12 2021 11:41 AM
Hi Dillen,
Only reason for the converstion is that i am connecting another turntable and tape, as the Beogram I have is completely broken  - got it as a give away from someone.
So I would like to convert the DIN's and speaker outlets to RCA's, as i also cannot find any of the old speaker plugs.
Thanks for your response
Regards
Hein
Dillen
Posts 13,191
Dillen replied on Mon, Jul 12 2021 11:49 AM
I would very much advice against converting speaker outputs to RCA.
The risk of shorting the outputs are to high.
DIN plugs are easily found on f.e. Ebay:
speaker din plug | eBay
Page 1 of 1 (4 items) | RSS
