MCL2AV Sound Settings permanently stored
Reinhard
Berlin
Posts 4
Reinhard Posted: Wed, Jul 14 2021 9:08 AM
Hello,
I have bought a pair of Beloab 18s and would like to place them in the link room. There I have a MCL2AV to which I have connected the BL18. With the Beolink 1000 I can change the volume and also the sound setting by pressing the sound button several times. How can I save the selected sound ( treble / bass ) settings permanently ?
By pressing Sound Store Store the settings are not stored permanently.
Storing the volume setting by pressing the Sound Store button will work.
The MCL2AV has SW 2.3 installed.
Cheers
Reinhard
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Jul 14 2021 11:02 AM
Reinhard:
I may be wrong but I don't think this is possible.  As far as I am aware there is no bass/treble control within the MCL2AV circuitry - I think it just passes the command back to the Audiomaster in the central room.  It would therefore be illogical to be able to set the default main room bass/treble from the link room.
Volume setting is different because the MCL2AV does have limited volume control circuitry built in.
David
Oxford
Posts 50
David replied on Wed, Jul 14 2021 12:53 PM
Page 9 of the guide on this link suggests that permanent settings are possible with a Beo4 remote.
https://www.avaservices.co.uk/assets/images/PDF-downloads/beolink-passive.pdf
Hope that helps. Please let me know if that works.
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Jul 14 2021 12:57 PM
David :
That's for the Beolink Passive.  The OP has the older MCL system with an MCL2AV.
David
Oxford
Posts 50
David replied on Wed, Jul 14 2021 1:01 PM
My mistake. I thought the operation might be similar.
Reinhard
Berlin
Posts 4
Reinhard replied on Wed, Jul 14 2021 4:39 PM
Hello David,
thanks for the Manual link. It helps to adjust the sound with a Beo4, it is easier as with the Beolink 1000.
Changing of sound works fine, but saving the settings does not.
Thank for your help.
Reinhard
Millemissen
Flensborg, Denmark
Posts 14,680
Here is a fitting link….if that helps you:
https://hifigoteborg.se/bo-manuals_nagon/MCL%20handbook.pdf
Page 1 of 1 (7 items) | RSS
DigiCert Secured Site Seal
