What are best b&o computer monitor speakers?
I have a max 33 in desktop and silver color.
It would seem expensive option but should I get two Levels, pair them and put it side by side the Apple mac monitor? Or should I do the same for emerge, or beosound 1?
i would like to connect them wired and not worry about battery also however
And if I have guests in drawing dinning room ideally i can also use them for entertainment purposes and shift locations?
Would appreciate to know what people are using for computer speakers
thank you
mir
geomir:What are best b&o computer monitor speakers? I have a max 33 in desktop and silver color. It would seem expensive option but should I get two Levels, pair them and put it side by side the Apple mac monitor? Or should I do the same for emerge, or beosound 1? i would like to connect them wired and not worry about battery also however And if I have guests in drawing dinning room ideally i can also use them for entertainment purposes and shift locations? Would appreciate to know what people are using for computer speakers thank you mir
