What are best b&o computer monitor speakers?
geomir
Posts 13
geomir Posted: Sun, Jul 18 2021 6:59 AM
I have a max 33 in desktop and silver color.
It would seem expensive option but should I get two Levels, pair them and put it side by side the Apple mac monitor? Or should I do the same for emerge, or beosound 1?
i would like to connect them wired and not worry about battery also however
And if I have guests in drawing dinning room ideally i can also use them for entertainment purposes and shift locations?
Would appreciate to know what people are using for computer speakers
thank you
mir
Aussie Michael
Melbourne, AU
Posts 3,730
geomir:
thank you
mir
It’s a question that I also ask myself on many an occasion and i never come up with a satisfactory answer other than the old Beolab 4 PC.
I am using 1 BeoPlay A1 via USB-C which i find convenient. If i wanted stereo, i would have to power each of them and then also connect a 3.5mm jack to both of them, so that’s 4 wires and too many for my desktop. As far as I can tell you can’t have two USB-C speakers connected on your PC and have them split left and right, you can only do that with the 3.5mm and connect one left and one right.
I asked a question yesterday about the Emerge to see if I could connect that via USB C to the PC and the response was that i need both the USB-C and a 3.5mm connected to the PC for sound. So that’s a step backward.
But if you don’t mind having 4 connections (2 USB and 2 3.5) then I think perhaps the Emerge would be suitable for a desk as they are ‘book’ size. You could disconnect them and use them in other locations.
I have thought about using my BL3s at a point as PC speakers, but then I would need to have 2 extra power provisions at my desk for them.
Page 1 of 1 (2 items) | RSS
