Beovision 11-55 vs 14-55
mbdj
Posts 74
mbdj Posted: Sun, Jul 25 2021 6:30 PM
What would be the Best Buy as a used tv ?
Millemissen
Flensborg, Denmark
Posts 14,680
There were several versions of the BV11.
If you can get one of the latest, I’d go for the BV11….in fact personally I’d almost go for the BV11 in any case.
But - as always - it depends on your use case!
This said, the BV14 is a good tv as well…….as long as you don’t expect it to be a SmartTV (which you also should not expect of the BV11).
It is said to run more troublefree now than in the beginning.
So, no absolute best recommendation for either of them from me.
Sandyb
Posts 2,186
Sandyb replied on Sun, Jul 25 2021 8:13 PM
The screen/ panel in the 14 is terrible
Avoid like the you know what
Mikipidia
Posts 2,169
Mikipidia replied on Mon, Jul 26 2021 12:16 AM
Agreed, late model 11-55 all day with an Apple tv attached. The only amazing thing about the 14-55 is the oak cover and you can put that on the 11-55 too!
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Pat
Posts 152
Pat replied on Mon, Jul 26 2021 1:22 PM
BV11, always. Also better sound, BV14 sounds weak. The dark side of the moon having BV11-55 - no lcd panels available anymore, if fails.
OlivierC
Posts 128
OlivierC replied on Tue, Jul 27 2021 10:55 PM
Beovision 11-55 MKIV (4 versions have been built since launch to end of production), IMHO.
https://archivedforum2.beoworld.org/forums/t/23424.aspx
Olivier
Page 1 of 1 (6 items) | RSS
